Date/Time: Tue, 26 Nov 2024 16:27:32 +0000
[User Discussion] - Draw Style - rectangle bottoms and tops
View Count: 232
[2023-11-10 09:25:55]
User740709 - Posts: 153
Currently, all Draw Styles (on Subgraph tab of a Study) that include rectangle bottoms and tops (transparent or not) are created in such a way that they always start at the close of the candle and go up (for tops) or down (for bottoms). I would assume that the logic would be such that for the rectangle bottoms to start at the bottom of a candle (low), while tops would start at the top (high) of the candle.
Is it possible to change the style in this manner?
Thank you.
All the best.
H.
[2023-11-10 12:33:47]
User431178 - Posts: 543
Where the drawing starts is controlled by the value contained in the subgraph.
If you want it to start in a different place use a different subgraph.
What study are you using and what are you trying to do?
[2023-11-10 13:58:18]
Thank you.
For example, I want to track delta of individual bars via DeltaMomentum study (from the list of User Contributed studies) directly on the bar chart, i.e. within the Chart Region 1. So whatever the color the delta is, I want to have a Transparent Fill Rectangle Bottom of that color (red or green) starting from the low instead of close of that bar and going to the bottom of the chart.
I have no clue how to change the subgraph of close to the subgraph of low.
Thanks!
H.
