Date/Time: Tue, 26 Nov 2024 16:33:49 +0000
Did you forget to bump SC_DLL_VERSION to 2564
View Count: 240
[2023-11-10 00:27:28] |
User719512 - Posts: 264 |
Hi Sierra Chart Engineering, I think you forgot to bump SC_DLL_VERSION to 2564. It still has 2563 and yet there are breaking changes in 2564 with signature changes to GetTextSize, GetTextSizeWithFont, and GetCurrentPosition. Aren't these breaking changes? Happy to be wrong here and look forward to your explanation either way. The new Graphics functions with OpenGL are fantastic. |
[2023-11-10 03:10:33] |
Sierra_Chart Engineering - Posts: 17182 |
Yes we will do that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-10 03:10:38
