Date/Time: Mon, 25 Nov 2024 09:09:34 +0000
[User Discussion] - Can I change the font for the toolbar?
View Count: 2169
[2013-05-04 13:45:32]
maxpi - Posts: 181
Is the toolbar font controlled by any setting in the Sierrachart Software? Could it be controlled by an operating system setting?
Edit: I'm running SC on a Linux system via Wine and the fonts on the toolbar are horrid, can't read them at all.
Date Time Of Last Edit: 2013-05-04 20:20:10
[2013-05-08 05:27:20]
maxpi - Posts: 181
Bump:
Changing screen resolution doesn't help with this... I moved some of the functions for which I would normally go to the toolbar over to the right click menu. Operationally it actually is a lot better that way and the fonts are readable on that menu.
[2013-05-08 06:05:27]
ganz - Posts: 1048
hi
the issue was resolved on Wine 1.5#
also I prefer to put micross.ttf into ../.wine/drive_c/windows/fonts/
gd lck
Date Time Of Last Edit: 2013-05-08 08:38:06
[2013-05-08 06:07:13]
The font which is used is hardcoded within Sierra Chart. It does take into consideration the DPI setting of the system.
It cannot be changed.
Date Time Of Last Edit: 2013-05-08 06:07:28
[2013-05-08 06:16:33]
ganz - Posts: 1048
Hello SC Support
What is the font you are using for the toolbar?
Thank you.
Date Time Of Last Edit: 2013-05-08 06:19:13
[2013-05-08 08:18:49]
Arial Narrow
