Date/Time: Tue, 26 Nov 2024 16:44:20 +0000
Micro Nat Gas futures
View Count: 439
[2023-11-09 16:23:49] |
Robert Wojczak - Posts: 144 |
Have they been added to trade through you guys. I don't see it in the drop down ion the symbols setting.... think it should be MNG... thank you
[2023-11-09 22:15:46] |
Sierra_Chart Engineering - Posts: 17182 |
We will complete the set up of NYMEX micro natural gas this evening.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-09 22:16:02
[2023-11-09 22:27:34] |
thank you
[2023-11-10 03:19:38] |
This is now complete. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
