Date/Time: Tue, 26 Nov 2024 15:38:18 +0000
Trading micros on ES/CL charts but displays wrong PnL
View Count: 237
[2023-11-09 16:14:56] |
JakeSmith - Posts: 9 |
Hello, I set my ES and CL charts to execute trades using the Micro counterparts. Looking at the trade activity logs, it does look to be working but on the actual chart the DPL in the top left is incorrect and displays the E-mini values as well as the open PnL being wrong. Is there a way to correct this? Thanks! |
[2023-11-10 18:43:32] |
Sierra_Chart Engineering - Posts: 17182 |
Yes. Check the Currency Value per Tick setting: Chart Settings: Updating Currency Value per Tick for Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
