Date/Time: Tue, 26 Nov 2024 16:16:03 +0000
[Programming Help] - How to create a volume moving average alert?
View Count: 379
[2023-11-09 02:31:52] |
User484096 - Posts: 13 |
I have plotted a moving average on volume. I want it to be alerted whenever current volume (bar closed ok too) exceeds 2x the previous bar volume moving average. However, I cannot figure out how to do it on the Alert >> Alert Condition. Also, is it possible to change the background color based on bull/bear bar? On the see screenshot, I want to be alerted on those high-volume bars. Thanks |
mvAlert.png / V - Attached On 2023-11-09 02:26:30 UTC - Size: 43.53 KB - 78 views |
[2023-11-09 05:58:39] |
User719512 - Posts: 264 |
Use the Study Subgraphs Divide/Ratio to get the ratio of current bar volume to previous bar volume moving average. Use Color Bar Based On Alert Condition (CBBOAC) to alert when this ratio is > 2. Color the alert bar based on Base Graph. |
test_Chartbook3.Cht - Attached On 2023-11-09 05:55:32 UTC - Size: 4.68 KB - 411 views Screenshot 2023-11-08 215702.png / V - Attached On 2023-11-09 05:58:06 UTC - Size: 90.59 KB - 82 views |
[2023-11-09 16:16:39] |
Infinite - Posts: 134 |
personally learning to to this yourself can expand your mind and help you develop great trading tools. Study/Chart Alerts And Scanning This link is full of everything you need, YOU CAN DO IT! |
