Date/Time: Tue, 26 Nov 2024 15:28:06 +0000
Orders not showing up on the dom while in replay mode.
View Count: 340
[2023-11-09 01:32:29]
User913840 - Posts: 21
Can orders on the bid and ask, paired with stacking and pulling be seen on the dom while replaying a chart. I can see orders hitting the bid and ask but I can't see any orders or pulling/stacking. I just have 1's in each bid and ask column that move with respect to the price.
image20231108_191704.jpg / V - Attached On 2023-11-09 01:11:32 UTC - Size: 6.89 MB - 76 views
[2023-11-09 03:15:28]
Sierra_Chart Engineering - Posts: 17181
What is the symbol being replayed?
[2023-11-09 03:39:30]
RIOT_MBO
[2023-11-09 14:38:37]
Use this symbol instead:
RIOT-NQTV
Download historical market depth data:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
And then you will have pulling and stacking data during a replay.
Also update Sierra Chart to the current version:
Date Time Of Last Edit: 2023-11-09 14:39:45
[2023-11-10 02:08:57]
The market order column isnt available for nasdaq symbols is it, or do I just need the level 12 package to see it?
[2023-11-10 03:35:55]
It is available for NASDAQ TotalView symbols and you will need Service Package 12 as well.
[2023-11-12 23:01:45]
Is it possible for me to update my plan from service package 11 to service package 12?
[2023-11-12 23:04:49]
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
