Date/Time: Tue, 26 Nov 2024 14:23:19 +0000
Numbers Bars Replay - Bid/Ask Orders Now Showing up
View Count: 268
[2023-11-09 01:13:36] |
User380392 - Posts: 4 |
Hello SC team, I finally setup the numbers bars with DOM on the same chart (still on trial, but plan to switch to a monthly subscription once my setup is working properly) When I do a multi-chart replay, bid/ask orders are not showing up on DOM (It just shows 1 on bid & 1 on ask) I have 2 different numbers bars with DOM on both charts in this chartbook (1m and 5m) and both charts are having the same issue. Please see the attached screenshot How do I fix this? Date Time Of Last Edit: 2023-11-09 01:21:04
numbersbars bid ask not showing up2.png / V - Attached On 2023-11-09 01:17:21 UTC - Size: 49.44 KB - 76 views |
[2023-11-14 16:10:44] |
Sierra_Chart Engineering - Posts: 17179 |
You need to download market depth data for the Date-Time range that you will be replaying: Market Depth Historical Graph: Downloading Of Historical Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-14 16:11:23
