Date/Time: Tue, 26 Nov 2024 14:25:47 +0000
Volume en delayed data feed
View Count: 217
[2023-11-08 22:16:34] |
User137942 - Posts: 10 |
Hello, i have not accurate volume on my delayed US equities symbols. I compare it on other platforms and they are toally false. Do i need to do something to change that? Thanks for your respond. |
[2023-11-14 16:11:48] |
Sierra_Chart Engineering - Posts: 17179 |
The data is correct. There can be no doubt about that whatsoever. Tell us one of the symbols you are referring to. To see the up-to-date volume, according to the delayed data, go to Window >> Current Quote Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-14 16:12:21
