Date/Time: Wed, 27 Nov 2024 02:34:30 +0000
twconfig Attached Orders' targets removed
View Count: 1076
[2014-07-22 20:48:08] |
Sawtooth - Posts: 4120 |
Is there any scenario where the targets in a saved twconfig could be removed in an autotrading system? The saved twconfig is not permanently changed; if I re-choose it from the drop-down, the targets reappear. I'm using two instances of the Trade Management for Study study, one for stops and one for targets, that reference two Spreadsheet System for Trading study's subgraphs. The missing targets occur intermittently using live data with Trade Simulation Mode ON. I cannot reproduce in Replay the same anomaly at the same location. In fact, I have never seen this anomaly in Replay. Using v1156. |
[2014-07-22 22:02:34] |
The condition under which this can occur is the setting of J80 or J81: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#AttachedOrderTargetOffset Otherwise, this would really be surprising and we are not sure why it would happen. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-22 22:02:46
