Date/Time: Tue, 26 Nov 2024 16:32:33 +0000
futures options trading
View Count: 278
[2023-11-08 17:21:29] |
User873205 - Posts: 9 |
Hi, Please advise on the following: 1) is it possible to trade options with Teton order routing? if not 2)Which service do you recommend; CQG or Rithmic? Thanks! |
[2023-11-08 20:07:15] |
Sierra_Chart Engineering - Posts: 17182 |
1. No. 2. Really what we recommend you do is use Sierra Chart for charting and trading futures and spreads. You can also chart options as well. And do your options order entry through either CQG or Rithmic using their platforms. Do not use Sierra Chart for options order entry. This is our recommendation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-08 20:08:54
