Date/Time: Tue, 26 Nov 2024 16:27:32 +0000
See executed order fills in another instance
View Count: 279
[2023-11-08 16:23:35] |
User454729 - Posts: 18 |
Hi there, I execute "micros" on the DOM in sub instance 2. I am trying to see these order fills on the "Minis" chart in my main instance but unable to. I have tried following the instructions here. Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) I have set chart settings->symbol-> symbol(action): CL, trade and current quote symbol: MCL, Use as trade only symbol: Yes, but still can't see the fills on the chart. Thank you for your help! |
[2023-11-08 20:15:44] |
Sierra_Chart Engineering - Posts: 17182 |
The first thing to do is to use look for the fills in the Trade Activity Log in the main instance. Instructions: Trade Activity Log: Viewing Historical Trade Activity Do you see them there? You then need to open a chart for the exact same symbol and set the Trade Account. Refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-09 18:02:06
[2023-11-08 22:22:57] |
THank you. Is there a way to have the fills be seen on chart without me having to do the export from sub-instnace 2 and importing it into main instance manually? THank you
[2023-11-09 17:44:20] |
I just found out that the fills/orders will show up in main instance as well with those settings! thank you!
