Date/Time: Tue, 26 Nov 2024 16:37:51 +0000
Two installations of Sierra on the same pc
View Count: 222
[2023-11-08 11:02:45]
User478380 - Posts: 184
Hi
With my current subscription, can I have another installation of sierra on the same pc that uses the same denali feed as my first install for no extra cost?
Can I also assign different rithmic routing settings to both versions - see attached - if both installs are on the same pc?
Lastly, how do I install a second version on my pc without the install conflicting with the first one?
Many thanks!
imagerouting.png / V - Attached On 2023-11-08 11:02:02 UTC - Size: 85.03 KB - 70 views
[2023-11-08 20:05:00]
Sierra_Chart Engineering - Posts: 17182
Yes this is all supported. Refer to:
Using Multiple Data and Trading Services at the Same Time
