Date/Time: Tue, 26 Nov 2024 16:25:40 +0000
Sierra loading more days for intraday chart than Data Limiting designates
View Count: 540
[2023-11-07 23:42:14] |
christostrades - Posts: 8 |
Today I added a new install of sierra for another trade service. Each chart in a chartbook was supposed to take in about 30 days of data, but it filled in months worth of volume and candles for intraday charts (5m). Now I've noticed my main instance is also taking in months of data for ES and NQ charts. The charts only need 1-3 days of data and I can't sort out how to fix it. I have "days to load for intraday chart data type" on 3 days, and load data limiting method is Use Number of Days to Load. But I Sierra isn't responding to the commands to reduce data usage. There is no mix up with this being a historical chart - it's clearly intraday. Any help is greatly appreciated.
Attachment Deleted. Screenshot 2023-11-07 at 6.34.47 PM.png / V - Attached On 2023-11-07 23:39:17 UTC - Size: 52.93 KB - 94 views |
[2023-11-08 21:20:37] |
Sierra_Chart Engineering - Posts: 17182 |
Refer to the information here regarding this: Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu) You will need to reload the chart with Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
