Date/Time: Tue, 26 Nov 2024 16:48:42 +0000
Simple alerts trigger from loading charts?
View Count: 237
[2023-11-07 22:43:20] |
User373245 - Posts: 42 |
Is there a way to eliminate simple alerts triggering from loading and unloading charts? if I do a replay...it sends 4 alerts on the loading of charts, as well as stopping the replay another 4. It's set to alert once per bar on a day chart. Not sure why the loading or stoping of charts sends an alert...the criteria of the alert is not present on the load and stop?
[2023-11-08 15:19:45] |
Sierra_Chart Engineering - Posts: 17182 |
Whatever you are seeing and the reason why, there would not be a way to change this. It is quite involved to analyze the specific reason of what is happening in your case. We are not sure why this would be happening. You do want to enable Alert Only Once Per Bar. Make sure that is enabled for all alerts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-08 15:20:18
