Date/Time: Tue, 26 Nov 2024 16:23:49 +0000
chart issue with objects not correlating
View Count: 207
[2023-11-07 17:53:24] |
User276793 - Posts: 52 |
I have this problem where when i dray a trend line on a minute chart it does not line up on the "trade" Tic chart. I have included an image. they are the same tickers and both volume based rollover. Not sure how to fix this. thanks |
tick and minute chart not lining up.PNG / V - Attached On 2023-11-07 17:52:54 UTC - Size: 129.75 KB - 62 views |
[2023-11-07 19:19:48] |
John - SC Support - Posts: 36300 |
Refer to the following: Lines/Rays or Other Chart Drawings Move After Drawing Them: Chart Drawings Are Misaligned After Changing the Period / Timeframe Per Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
