Date/Time: Tue, 26 Nov 2024 16:33:32 +0000
Data feed pricing
View Count: 206
[2023-11-07 16:52:01] |
nwills - Posts: 16 |
I have read through all the material and still need clarification on my specific needs. I currently have: -Integrated Sierra Chart with Advanced Features (Service Package 11)- along with: -Denali Exchange Data Feed CME / CBOT / NYMEX / COMEX Exchanges- I would like to have ES along with MES real time data with DOM. Also US equities with non delayed real time data (no DOM). Can you please indicate what I need to activate or whether my current package and data is sufficient? |
[2023-11-07 16:55:32] |
John - SC Support - Posts: 36300 |
With regards to the CME data, what you have now is fine. You currently have the "CME with Market Depth for Non-Professional Trading Accounts" exchange active. Note that this is just the CME exchange, not the entire CME Group - so you do not have access to any real-time data from us for the COMEX, NYMEX, or CBOT exchanges. The ES and MES are traded on the CME exchange, which is why you are fine with the above. -- With regards to the U.S. Equities - you would need to activate the "U.S. Equities Consolidated Tape" exchange to get this data from us. Follow the instructions at the following link to setup this exchange: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
