Date/Time: Tue, 26 Nov 2024 16:43:14 +0000
Additional setting for Heatmap
View Count: 405
[2023-11-07 15:28:46] |
User135370 - Posts: 162 |
Hi John/Sierra I like to have the Historical Market Depth study on my chart particularly to see where the depth is but I don't like the bookmap style heatmap, is there a way that I can show the Depth numbers with the thresholds without it drawing blocks on the chart? Even if I make them the same as background you can see they will appear if I draw a line or rectangle level. If it is not possible to have a setting to disable the drawing is there an alternative study that displays depth which allows you to only display depth above a certain number? |
Heatmap.png / V - Attached On 2023-11-07 15:25:15 UTC - Size: 73.23 KB - 111 views |
[2023-11-07 16:50:44] |
John - SC Support - Posts: 36300 |
There is not a way to do this. We do have this on our list of features to get to - but we can not say when we will get to any particular feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-07 17:54:52] |
Understood John appreciate your response and considering the request. Thank you |
