Date/Time: Tue, 26 Nov 2024 16:28:50 +0000
[Programming Help] - DailyOHLC example from Studies8 is giving a compile error?
View Count: 225
[2023-11-07 09:25:54]
User92573 - Posts: 530
Dear Support
Any thoughts as to why I am receiving a compile error with a direct copy of the code from "SCSFExport scsf_DailyOHLC(SCStudyInterfaceRef sc)"?
#include "sierrachart.h"
#include "scconstants.h"
SCDLLName("DailyOHLC_1")
Error message:
DailyOHLC_1.cpp.cpp(line): error C3861: 'CalculateDailyOHLC': identifier not found
Checking ...
#include "scstudyfunctions.h"
  User note: The functions in this file are intermediate level functions you can
  copy and call from your primary scsf_ functions. These functions are not
  complete study functions. They are used by primary study functions to
  perform calculations. Where you see _S at the end, this means that the
  function is a single step function, and only fills in the array element
  at the index specified by the Index parameter.
This function is being called by the SC example study "DailyOHLC" which comprises the code found in Studies8.cpp "SCSFExport scsf_DailyOHLC(SCStudyInterfaceRef sc)".
Including the header file ... #include "scstudyfunctions.h" gives more compile errors.
So, absolutely no idea why the example code fails.
Help appreciated.
Many thanks
Date Time Of Last Edit: 2023-11-09 16:54:45
