Date/Time: Tue, 26 Nov 2024 16:34:24 +0000
TPO Chart does not keep merges
View Count: 434
[2023-11-07 06:17:20] |
AKR - Posts: 523 |
I have been using a certain TPO chart for months. Since I did update to most recent version, whenever I close the CB and open it again, all my merges are gone. Any advice of a setting I am having wrong? |
[2023-11-07 06:52:06] |
Sierra_Chart Engineering - Posts: 17182 |
Attach the Chartbook here and we will test. Instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-07 08:07:33] |
AKR - Posts: 523 |
attached
Chartbook21.Cht - Attached On 2023-11-07 08:07:10 UTC - Size: 7.94 KB - 105 views |
[2023-11-07 22:13:42] |
We see the reason for the problem. We are resolving this now.
[2023-11-08 04:50:47] |
Update to the latest release to resolve this.
[2023-11-08 14:57:40] |
AKR - Posts: 523 |
This seemed to have worked. Now I did close the CB, then I changed the Data/Trade Service. Then I did open a CB with the symbols of that service (apertos). Then I did open the CB with symbols for CQG again and now mergers gone again ....
[2023-11-08 15:16:27] |
When the symbol of a chart changes absolutely the TPO splits and merges will be reset. There is no way to avoid that at all.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-08 15:16:43
[2023-11-08 19:17:14] |
AKR - Posts: 523 |
I did not say I changed the symbol. 2 chartbooks (with same content), one symbols CQG, other Symbol apertos, so denali feed I guess. CQG CB open and working on it. Close that. Change feed to apertos. Open CB apertos symbol. Additionally openinf CB CQG symbol without changing that symbol. Mergers there gone. |
[2023-11-08 19:58:29] |
The symbol may be changing without you being aware of it. Make sure this option is set to No: Advanced Service Settings: Translate Symbols Automatically in Chartbooks and Quote Boards (Global Settings >> Advanced Service Settings >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-08 20:14:53] |
AKR - Posts: 523 |
No, they are not.
[2023-11-08 21:02:36] |
Provide the chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart And are you testing with the latest Sierra Chart version? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-09 06:33:41] |
AKR - Posts: 523 |
problem seems gone.
[2023-11-10 03:19:56] |
That is good.
