Date/Time: Mon, 16 Sep 2024 19:45:41 +0000
Profit/Loss Limit Percent
View Count: 384
[2023-11-06 22:42:25] |
User305661 - Posts: 15 |
Hi, I'm wondering if you would be able to add a variable for percent of account. Just like in the broker side, but for the new user settings? If you change the currency value, I'm assuming it starts the next trading day, and is there a time cut-off to change it? Also are there any updates on when it will become available for live trading accounts, the last update was mid September 2023? |
Profit Loss Percent.PNG / V - Attached On 2023-11-06 22:40:23 UTC - Size: 104.96 KB - 81 views |
[2023-11-06 23:48:00] |
Sierra_Chart Engineering - Posts: 16387 |
This will be looked into later. It will become available for live trading, probably as early as next week with Stage 5.
[2023-11-30 23:43:45] |
After supports last post on the 6th, I changed my settings to -321 as the trigger value and 'use liquidation only mode' and then hit commit but every time it would repopulate to 'flatten positions' early last week or so it finally updated with the 'use liquidation only mode' and yesterday was the 1st day i was close to the -321 in live account and it did not liquidate me and let me keep on trading after the drawdown was more than -321 I also have amp as a broker, so maybe thats why because its not Stage5 and everything is not fully functioning at amp, as this is still being implemented as a new feature |
setting 1.PNG / V - Attached On 2023-11-30 23:30:54 UTC - Size: 73.95 KB - 50 views |
[2023-12-01 22:10:26] |
This is not supported for live trading with any broker at this time. First will be Stage 5 and we expect this coming week by the end of the week.
[2024-01-30 19:29:15] |
Hi, Im wondering if there has been any progress with this feature since Dec 1 2023, when i last heard from yall about this feature? |
