Date/Time: Tue, 26 Nov 2024 16:47:25 +0000
Fonts are too big and bold and it is not loading correct chart graphic.
View Count: 268
[2023-11-06 19:54:50] |
AbdulazizKHF - Posts: 4 |
Here is a current chartbooks view and how it should look like in original one.
image_2023-11-07_00-52-35.png / V - Attached On 2023-11-06 19:52:51 UTC - Size: 58.04 KB - 83 views Screenshot_3.png / V - Attached On 2023-11-06 19:54:35 UTC - Size: 881.47 KB - 68 views |
[2023-11-06 19:55:27] |
I imported same chartbook file but there are huge difference.
[2023-11-06 20:31:26] |
File attached
Tradingriot_SC-crypto.Cht - Attached On 2023-11-06 20:31:21 UTC - Size: 61.32 KB - 245 views |
[2023-11-06 21:40:56] |
Sierra_Chart Engineering - Posts: 17182 |
Adjust the font sizes through Global Settings >> Graphics Settings >> Fonts: Or if the chart has its own graphics settings set, then use Chart >> Graphics Settings >> Fonts. We recommend resetting them to default and then changing them to what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-06 21:41:35
