Date/Time: Wed, 27 Nov 2024 02:20:04 +0000
Setting a trailing stop without using SC to trade
View Count: 1026
[2014-07-22 17:50:44] |
Lynda Kane - Posts: 4 |
Hi, I don't trade through SC but want to set trailing stops with alerts on the stocks I own. How do I do this. Looked through the documentation but can't find it anywhere. Thanks, Lynda |
[2014-07-22 18:19:41] |
This can be done by using Simple Alerts on a chart for the stock: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-22 18:20:10
