Date/Time: Tue, 26 Nov 2024 16:21:15 +0000
DOM Bid/Ask Delta
View Count: 627
[2023-11-06 14:34:27] |
Stav - Posts: 104 |
Hi John Sierra Chart, I think others may have asked about this, and just really want to know if its possible. Can I or is there a field available that can show the delta (bid - ask) for each price traded on the DOM. Is it possible to display this sum next to the current traded bid/ask volumes in customize DOM settings? Many thanks. Stephen |
[2023-11-06 14:50:59] |
Sierra_Chart Engineering - Posts: 17182 |
No you have to use the Volume by Price study for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-06 14:51:45
[2023-11-06 15:59:24] |
Stav - Posts: 104 |
Hi, Yes, I've done that just thought this was also possible as DOM fields. Thanks. Stephen |
