Date/Time: Tue, 26 Nov 2024 16:16:13 +0000
Which package to get if I want to sim trade with delayed data?
View Count: 288
[2023-11-06 11:12:06] |
User799255 - Posts: 24 |
Hi, Can I get some advice on which packages are required to sim trade on delayed data using market depth on CME? I followed from this page Simulated Futures Trading Service: Setup Instructions and tried to turn ontrading evaluator but it looks like it needs to be enabled. Thank you! Date Time Of Last Edit: 2023-11-06 11:25:14
Untitledw.png / V - Attached On 2023-11-06 11:25:11 UTC - Size: 33.31 KB - 68 views |
[2023-11-06 12:39:26] |
Sierra_Chart Engineering - Posts: 17182 |
Service Package 3. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Account Control Panel" on the Sierra Chart software menu. On the displayed webpage, click on "Activate Services". Or you can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password if necessary. 2. Choose the particular Service Package and the number of Months that you want and press the "Update/Set" button. If you are on a Trial, you will first need to add sufficient credit to your account to pay for the chosen Service Package/Months. In this case, refer to the step below. Once that is done you can then choose the Service Package and number of Months. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
