Date/Time: Tue, 26 Nov 2024 16:35:55 +0000
Numbers on lines
View Count: 235
[2023-11-06 10:34:12]
User478380 - Posts: 184
Hi
Please see attached
imagelines.png / V - Attached On 2023-11-06 10:34:03 UTC - Size: 35.87 KB - 64 views
[2023-11-06 16:28:08]
John - SC Support - Posts: 36300
You have selected an option that is waiting for you to select a drawing to do something to it. For example, if you selected "Tools >> Move Drawing" then each drawing will have a number displayed allowing you to select it to then move it. Refer to the following:
Chart Drawing Tools: Adjust Drawing - Menu and Control Bar Button Method
To get "out" of this mode without actually selecting anything, select a drawing tool (such as Pointer).
[2023-11-06 16:31:56]
Thanks very much !
