Date/Time: Tue, 26 Nov 2024 16:24:16 +0000
Detele .scid and .dly file
View Count: 314
[2023-11-06 07:35:47]
User990777 - Posts: 12
Hi Support,
Good day to you.
I would like to check if it is safe to delete unused .scid and .dly files from "C:\SierraChart\Data" because i downloaded too many symbol or chart.
take up too many harddisk space.
My question if i detele directly from C:\SierraChart\Data e.g Gbpjpy.dly , GBPJPY.scid will it corrupt my installation ?
Many thanks in advance.
[2023-11-06 16:22:16]
John - SC Support - Posts: 36300
Refer to the following:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
In particular note steps 8 and 9 that tell you the files to then delete.
