Date/Time: Tue, 26 Nov 2024 16:23:10 +0000
Dyanmic Fixed Time for Volume Profile
View Count: 263
[2023-11-06 06:08:31] |
Christopher Lecusay - Posts: 6 |
Hello, I was wondering if it was possible for the volume profile to be fixed to one volume profile that's always calculating the specified amount of days specified in "Fixed Time" however, as we scroll left the volume profile would dynamically change to the past based on however many length in time was specified to the left of it. So for instance if I had the fixed time be at 5 days it would calculate the volume profile from the current day (let's say current graph shows the latest date to be 11/6/23 9:30:32am to 10/30/23 9:30:32am). However, if I scroll left all the way to 11/2/23 13:45:52pm then the volume profile would dynamically change to 10/26/23 13:45:52pm. Is that possible if so how do I do it? If not is it possible for it to be created in the future? |
[2023-11-06 16:20:23] |
John - SC Support - Posts: 36300 |
This is not something we currently have. The closest available is to use the "Visible Bars" and have the amount of time you want to view within the Visible area (such as 5 days). We take all input for feature requests, we just can not say when we will get to any particular feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
