Date/Time: Wed, 27 Nov 2024 02:40:44 +0000
How can I purge the Forex quantity when I trade NQ after trading FX
View Count: 1077
[2014-07-22 17:35:41]
User40520 - Posts: 62
I seems to retain the FX quantity at times. Is there a way to purge the memory?
[2014-07-22 18:23:48]
You need to change the quantity on the Trade Window and if you go to the Set tab of the Trade Window, you can change the order quantity buttons. Here is the documentation:
https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowControls
Once this is done, you should save the Trade Window configuration with the quantities that you want and then you can change to those at any time. Here is the documentation:
https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations
Date Time Of Last Edit: 2014-07-22 18:59:42
[2014-07-22 18:48:30]
many thanks
