Date/Time: Tue, 26 Nov 2024 17:36:50 +0000
Apex account serious issues
View Count: 328
[2023-11-06 00:21:33] |
User690628 - Posts: 8 |
Hi. I have multiple Apex Trader Funding accounts but one of mine shows that I am down hundreds of points in Sierra Chart whilst up up hundreds of points in actuality. More recently it shows I am short 4 contracts in NQ when I never placed a trade. It all shows up normally and as expected on Apex's side but have no clue how it's showing this on Sierra's side. Naturally, I need this sorted out so I can proceed with confidence. For reference, I believe it showed I was down over 300 points on Friday and now shows I'm short 4 contracts and down 143 points. Very concerned how this is possible and appreciate your assistance in resolving the issue. Thank you. |
[2023-11-06 00:24:47] |
Sierra_Chart Engineering - Posts: 17182 |
Regarding the position quantity, refer to: Trading Information Windows: Incorrectly Reported Trade Position Quantity Regarding the profit/loss you are referring to, most likely it is the Daily Profit/Loss. Refer to: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
