Date/Time: Tue, 26 Nov 2024 16:25:31 +0000
Global chart DOM
View Count: 238
[2023-11-05 23:41:07] |
User216753 - Posts: 19 |
I'm trying to have the stacking and pulling depth on NQ be it's own setting because I have the tick size set to 1.0 instead of .25. Therefore the depth amount needs to be much more than the S&P in which I'm using the stock tick size. How do I individuate the two, I'm not seeing how to get the NQ out from under the global setting? Date Time Of Last Edit: 2023-11-05 23:42:03
[2023-11-06 16:14:26] |
John - SC Support - Posts: 36300 |
We are not really understanding what you are wanting to do. We understand you have the Tick Size set to 1.0 for the NQ, but your Market Depth data is still going to be displayed at the original tick size. Please give us more information on what you want to see or do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-06 18:11:49] |
I can't get the charts to let me have ES set at 15 and NQ at 40. If I change NQ to 40 that changes ES to 40. If I change ES to 15 that changes NQ to 15. I want to have separate market depth control over each symbol. Right now I don't have that. |
[2023-11-06 21:56:38] |
You can control the number of Market Depth levels per chart. Refer to the following setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-06 23:46:58] |
That is not the function I am referring to. I'm talking about the max depth for pulling and stacking under DOM settings. Whatever this is set to is making that the pulling and stacking depth for all symbols, I need this number to be different for different symbols.
[2023-11-07 00:17:41] |
Sierra_Chart Engineering - Posts: 17182 |
There is no support for this.
