Date/Time: Tue, 26 Nov 2024 16:32:32 +0000
Since upgrade last week I can't freely move chart U/D/L/R
View Count: 336
[2023-11-05 15:20:39] |
Kpac - Posts: 8 |
Hey there, I have tried running the settings from the attached video, which work well in the past. Now my charts are unable to move freely with hand tool? https://www.youtube.com/watch?v=PvUv6t86gNc&t=619s |
Screenshot 2023-11-05 at 10.17.13 pm.png / V - Attached On 2023-11-05 15:19:09 UTC - Size: 105.95 KB - 69 views Attachment Deleted. Screenshot 2023-11-05 at 10.17.21 pm.png / V - Attached On 2023-11-05 15:20:03 UTC - Size: 82.72 KB - 75 views |
[2023-11-06 01:22:03] |
Sierra_Chart Engineering - Posts: 17182 |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-06 05:35:03] |
Kpac - Posts: 8 |
https://www.sierrachart.com/image.php?Image=1699248871424.png
[2023-11-06 05:37:10] |
Kpac - Posts: 8 |
To clarify the issue, I could move my chart around freely up, down left right, now the hand tool cant do so? Is this a bug with new version? I deleted the old version and just opened this one, was I meant to keep both? I am running Sierra chart application from my virtual windows desktop/ which is also my mac desktop with parallells. Thank you. |
[2023-11-06 06:25:39] |
We are not observing any problem with this. So you cannot move the chart in any direction either left or right or up and down? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-06 06:31:43] |
Kpac - Posts: 8 |
Thats correct, I used the video I added in the first message to set up my preferences a few weeks ago and it has been working perfectly. Now I cant freely move the chart around with the hand tool? I can move the chart from the bottom areas and side area, but not freely ON the chart, have enabled some 'lock' chart setting? |
[2023-11-06 08:36:38] |
Kpac - Posts: 8 |
Hey there, So I have loaded an old chart and it has the same settings under Global/tools/ and it works fine? But any new chart wont allow it? Doe that help? |
[2023-11-06 08:52:07] |
Kpac - Posts: 8 |
Hey there, update. I worked it out. I had to manually selct the hand tool in the sub menu to over ride the default pointer preset. This is so insane how long this took, is there going to be an update to sierra to make it more intuitive, considering how expensive it is? Is there a plan to modernise it at some stage? Its great in some ways and a nightmare in others. K |
[2023-11-06 14:48:25] |
Well if the Hand tool was not selected that is the problem. We trusted that you did have that selected. You can add Control Bar buttons for the hand tool and other tools to visually see what is selected: Control Bar There is nothing to modernize. We are not going to butcher Sierra Chart, like so many others do with there software, and make it woke, nonsensical and insane. That will never happen. Sierra Chart is quality software. We are not going to ruin it. There is no such thing as modernization. Sierra Chart is superb as it is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-06 14:50:27
