Date/Time: Tue, 26 Nov 2024 16:15:28 +0000
ACSIL DRAWSTYLE_VALUE_ON_HIGH - formatted as 0.0f or INTEGER
View Count: 232
[2023-11-05 11:40:40]
User92573 - Posts: 530
Dear Support
I've probably missed a simple explanation in the examples as to how I can change "DRAWSTYLE_VALUE_ON_HIGH etc." which currently displays the number as a float, to either being formatted as 0.0f or as an INTEGER.
Any help or direction appreciated.
Thank you.
[2023-11-05 19:19:02]
Sierra_Chart Engineering - Posts: 17182
Check the Value Format setting for the study.
[2023-11-06 09:04:41]
Thank you, I do use Value Format but as there is more than 1 subgraph I was hoping I could format the "drawstyle text" independently.
Any thoughts would be appreciated.
PS. I notice there was a prior request / thread.
sc.ValueFormat for specific subgraphs
Date Time Of Last Edit: 2023-11-06 09:24:18
