Date/Time: Tue, 26 Nov 2024 16:25:29 +0000
Remote Build for GDIExample.cpp gives errors about use of deleted functions
View Count: 458
[2023-11-05 02:51:27]
User719512 - Posts: 264
Hi Sierra Chart Engineering,
I noticed that your remote build service fails to compile GDIExample.cpp. Gives a many errors about use of deleted functions and such.
I even trimmed the study down to something trivial and got the following output.
-- Starting remote build of Custom Studies Source files: GDIExample.cpp. 64-bit -- 19:45:55
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
GDIExample.cpp: In function 'void DrawToChart(HWND, HDC, SCStudyInterfaceRef)':
GDIExample.cpp:28:27: error: use of deleted function 'n_ACSIL::s_GraphicsBrush::s_GraphicsBrush()'
28 | n_ACSIL::s_GraphicsBrush GraphicsBrush;
In file included from sierrachart.h:22,
from GDIExample.cpp:1:
scstructures.h:3383:8: note: 'n_ACSIL::s_GraphicsBrush::s_GraphicsBrush()' is implicitly deleted because the default definition would be ill-formed:
3383 | struct s_GraphicsBrush
scstructures.h:3383:8: error: use of deleted function 'n_ACSIL::s_GraphicsColor::s_GraphicsColor()'
scstructures.h:3337:8: note: 'n_ACSIL::s_GraphicsColor::s_GraphicsColor()' is implicitly deleted because the default definition would be ill-formed:
3337 | struct s_GraphicsColor
scstructures.h:3337:8: error: use of deleted function 'n_ACSIL::s_GraphicsColor::u_Color::u_Color()'
scstructures.h:3339:8: note: 'n_ACSIL::s_GraphicsColor::u_Color::u_Color()' is implicitly deleted because the default definition would be ill-formed:
3339 | union u_Color
scstructures.h:3349:5: error: union member 'n_ACSIL::s_GraphicsColor::u_Color::RGB' with non-trivial 'constexpr n_ACSIL::s_GraphicsColor::u_Color::<unnamed struct>::<constructor>()'
3349 | } RGB;
-- End of Build -- 19:46:00
This is the (modified) file I used for compliation: GDIExample.cpp
#include "sierrachart.h"
SCDLLName("GDI Example")
void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc);
SCSFExport scsf_DrawToChartExample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Draw To Chart Example";
    sc.GraphRegion = 0;
    sc.AutoLoop = 0;
    return;
  sc.p_GDIFunction = DrawToChart;
void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc )
  return;
[2023-11-05 15:44:34]
binaryduke - Posts: 369
Same situation here:
-- Starting remote build of Custom Studies Source files: GDIExample.cpp. 64-bit -- 09:43:00
GDIExample.cpp:53:27: error: use of deleted function 'n_ACSIL::s_GraphicsBrush::s_GraphicsBrush()'
53 | n_ACSIL::s_GraphicsBrush GraphicsBrush;
3349 | } RGB;
GDIExample.cpp:59:25: error: use of deleted function 'n_ACSIL::s_GraphicsPen::s_GraphicsPen()'
59 | n_ACSIL::s_GraphicsPen GraphicsPenForRectangle;
scstructures.h:3366:8: note: 'n_ACSIL::s_GraphicsPen::s_GraphicsPen()' is implicitly deleted because the default definition would be ill-formed:
3366 | struct s_GraphicsPen
scstructures.h:3366:8: error: use of deleted function 'n_ACSIL::s_GraphicsColor::s_GraphicsColor()'
GDIExample.cpp:74:27: error: use of deleted function 'n_ACSIL::s_GraphicsBrush::s_GraphicsBrush()'
74 | n_ACSIL::s_GraphicsBrush HollowBrush;
GDIExample.cpp:92:27: error: use of deleted function 'n_ACSIL::s_GraphicsColor::s_GraphicsColor()'
92 | n_ACSIL::s_GraphicsColor GraphicsColor;
GDIExample.cpp:102:25: error: use of deleted function 'n_ACSIL::s_GraphicsPen::s_GraphicsPen()'
102 | n_ACSIL::s_GraphicsPen GraphicsPen;
-- End of Build -- 09:43:04
[2023-11-05 20:36:53]
Sierra_Chart Engineering - Posts: 17182
We will check on this.
[2023-11-08 23:09:30]
This is fixed by the header file updates to add constructors for the affected classes in v2563.
[2023-11-09 03:14:12]
That is good.
