Date/Time: Tue, 26 Nov 2024 16:44:31 +0000
Only showing sim account and be logged in rithmic apex data
View Count: 413
[2023-11-04 19:40:29] |
Amberstone Investments - Posts: 4 |
Please i need help, im logged on the apex trade service on sierra chart everything works when i go to trade activity log it show my apex account but only there, when i go to the trade menu it only shows the sim, i try to switch to live but it doesnt show the account either
Attachment Deleted. Screenshot 2023-11-04 193936.png / V - Attached On 2023-11-04 19:40:04 UTC - Size: 19.4 KB - 91 views Screenshot 2023-11-04 193922.png / V - Attached On 2023-11-04 19:40:12 UTC - Size: 17.41 KB - 86 views |
[2023-11-05 19:49:09] |
Sierra_Chart Engineering - Posts: 17182 |
Make sure Trade Simulation Mode is disabled: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes If you still do not see the account listed on the Trade Window it is because Rithmic is not sending it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-05 19:49:14
[2023-11-05 19:52:47] |
The funded account is sim becouse is 1 phase, i already try to turn off sim and the account is not there
[2023-11-05 19:59:02] |
Contact Rithmic about this. We cannot help with it. They are not sending any accounts. And whatever accounts you see in the Trade Activity Log are irrelevant.
[2023-11-05 20:12:39] |
But what is the problem? If i wait for the week start you think this will solve
[2023-11-06 12:40:26] |
[2023-11-09 03:29:35] |
Ticks - Posts: 183 |
Did you read and follow the Apex instructions to open RTraderPro and log into the platform first and sign all the user agreements? Once you have completed that. Reopen RTraderPro and log into the platform. If you see your Apex accounts in RTraderPro, then they will show up in Sierra Charts. |
