Date/Time: Tue, 26 Nov 2024 17:39:07 +0000
Historcial Charts
View Count: 226
[2023-11-03 11:34:37] |
Alex Shterenberg - Posts: 9 |
Hi Guys I like to pull up historical charts for research. For example I change the symbol to MESH22_FUT_CME[M] 5 min, and pull up the intraday chart everything is ok. Is there any way to save it? Because when I save the chartbook and then reopen it, the chart only goes back to Jan 16 2022 and misses all of January. I have to go to EDIT>DELETE ALL DATA AND DOWNLOAD to reload the chart again, and sometimes it does not reload. So basically I am looking for a way to save historical charts that I can reference or replay for research. Thank You |
[2023-11-03 15:14:10] |
Sierra_Chart Engineering - Posts: 17182 |
What you are asking about is increasing the amount of data loaded in the chart. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
