Date/Time: Tue, 26 Nov 2024 17:37:43 +0000
Overlaying MTF study onto a Tick chart
View Count: 291
[2023-11-03 09:31:24]
pjk0225 - Posts: 34
Are there incompatibilities when applying a study from a certain timeframe (10 min, etc) to an order-based tick chart?
In my case, I tried applying a moving average on a 10 min chart directly onto a tick chart of the same symbol and it seemed to mess up the chart.
Do I need to do something differently?
[2023-11-03 15:24:41]
John - SC Support - Posts: 36300
The only thing you need to be aware of is how the data is copied from the one chart to the other. Refer to the following:
Study/Price Overlay Study: Data Copy Mode
[2023-11-04 13:10:47]
pjk0225 - Posts: 34
Thank you, got it to work.
