Date/Time: Tue, 26 Nov 2024 17:31:11 +0000
Replay Chart - pause on new DailyLow
View Count: 249
[2023-11-03 08:43:59] |
User450094 - Posts: 1 |
Hi, While Replaying a chart I would like the replay to pause once a new DailyLow happens. Is it possible to make replay mode pause when an alert or event such as a new dailyLow happens? Thanks |
[2023-11-03 15:22:25] |
John - SC Support - Posts: 36300 |
You would have to create a custom study to do this, but it is possible. Refer to the following in particular: sc.PauseChartReplay() Or you can pay to have someone create the study for you. A list of programmers can be found at the following link: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
