Date/Time: Sun, 22 Dec 2024 06:05:18 +0000
[Locked] - Crosshair cursor issue
View Count: 1840
[2014-07-22 15:05:09]
User87197 - Posts: 65
Hi SC. I'm not sure why it might be but since I've installed the 1157 release the Crosshair tool doesn't change the cursor to a crosshair shape and remains as the normal pointer cursor. The functionality of the tool remains correct but was just wondering if you know how I can fix this?
Many thanks!
[2014-07-22 17:03:21]
Select Global Settings >> Tool Settings >> Chart Values.
Make sure Always Active When Selected is unchecked.
Make sure the Crosshair Color is not the same as the chart background color.
[2014-07-22 21:43:05]
Thanks for the reply. The problem has mysteriously disappeared several hours after checking the details that you mentioned. Hopefully it's all fine now. Very much appreciated, you're the best!
[2014-12-02 17:49:53]
User28366 - Posts: 14
How do I change the background color whether or not a condition has been met? Some of my charts are black, some are white, but I want a light grey?
THanks,
[2014-12-02 18:04:15]
You have posted in the wrong thread. Start a new Support Request:
https://www.sierrachart.com/index.php?page=PostingInformation.php
Date Time Of Last Edit: 2014-12-02 18:04:28
