Date/Time: Tue, 26 Nov 2024 17:40:50 +0000
Funded AMP futures account
View Count: 344
[2023-11-03 03:49:01] |
Charles Kissee - Posts: 1 |
I have a funded AMP futures account. Can this be set up for Teton Futures Order routing and qualify me for real time CME data ? Or do I have to open an account with Stage 5, Edge Clear, or Cannon trading to qualify for real time data ? Would I have to login to AMP futures account monthly if so ? I also have a TD Ameritrade funded futures account. Will this suffice ?
[2023-11-03 15:12:20] |
John - SC Support - Posts: 36300 |
Sierra Chart works with AMP, using either CQG or our Teton Order Routing Service. If you are just using the AMP account to verify your Non-Professional standing for the CME Group, then it really does not matter if you using CQG or Teton for this - and you will have to connect at least once a month to verify your standing. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Otherwise, if you are trading this account, then we certainly recommend using the Teton Order Routing service for trading the CME Group. If you let us know which order routing service you will be using, then we can point you to the proper instructions to connect your Sierra Chart software. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
