Date/Time: Tue, 26 Nov 2024 17:19:27 +0000
[User Discussion] - unable to open existing chartbooks
View Count: 247
[2023-11-02 20:38:57] |
User806937 - Posts: 7 |
Hi there, I have not used my sierra chart platform for a while and now I'm unable to open up previously saved chartbooks. It says the chartbook file is not compatible. contact sierra chart support for help with converting it. your help would be much appreciated thanks |
[2023-11-02 21:47:12] |
Sawtooth - Posts: 4120 |
Here are the instructions to update older chartbooks: Chartbooks (Workspaces): Opening Older Chartbooks |
