Date/Time: Tue, 26 Nov 2024 17:36:29 +0000
DTC vs ACSIL
View Count: 247
[2023-11-02 18:23:35] |
User887126 - Posts: 66 |
Hi SC team or anyone from the board that want to help, What is the difference between DTC protocol vs just writing custom ACSIL code and trading directly from SC? what are the advantages and disadvantages? Is submitting order through DTC faster than submitting through ACSIL custom auto trading script? I am using Teton and denali feed. It is already directly connected to the exchange server and order can be executed in <1ms from what i understand. can you guy simplify and explain? i am interested in trading only ES, NQ and trying to determine the best way to reduce the lag time. Thank you in advance. Date Time Of Last Edit: 2023-11-02 18:26:52
[2023-11-03 14:58:47] |
Sierra_Chart Engineering - Posts: 17182 |
Yes the DTC Protocol Server is faster. Is submitting order through DTC faster than submitting through ACSIL custom auto trading script?
However, the DTC Protocol Server provides no market data in the case of data from exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
