Date/Time: Wed, 27 Nov 2024 02:23:18 +0000
Data differences
View Count: 1268
[2014-07-22 13:46:02]
User53196 - Posts: 13
I run the 5 minute tick data side by side with Interactive Brokerss data. The difference is 200-400. How can this be? Confirmation with other traders indicates that Sierra is the incorrect one. thanks
[2014-07-22 16:40:40]
When you say:
5 minute tick data
What Data or Trading service does this come from?
And what is the difference of 200 to 400?
Date Time Of Last Edit: 2014-07-22 16:40:56
[2014-07-22 19:08:06]
I use Interactive Brokers data feed. Interactives reading on the tick for example may be -200 where the Sierra number is +150. running side by side. Settings are the same, just don't understand why the variance
[2014-07-22 19:17:13]
Sawtooth - Posts: 4120
This post on Big Mikes might be helpful to understand variances in the TICK between data feeds:
https://www.bigmiketrading.com/sierra-chart/29642-sierra-chart-s-new-data-feed-3.html#post406884
Go to post #21 for the context.
[2014-07-22 19:31:19]
We can only provide you documentation on how the Sierra Chart Market Statistics data feed works. Refer to:
