Date/Time: Tue, 26 Nov 2024 17:18:02 +0000
Everything works but randomly get this error every couple seconds. Im on a apex account
View Count: 295
[2023-11-02 15:20:27]
Sylent - Posts: 6
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2. | 2023-11-02 11:15:27.876
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | New receive buffer size: 0 | 2023-11-02 11:15:27.876
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Connecting to IP: -----. | 2023-11-02 11:15:27.876
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-11-02 11:15:28.917 *
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | CloseSocket call. | 2023-11-02 11:15:28.917
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Closed. | 2023-11-02 11:15:28.917
cleared ip
[2023-11-02 15:42:55]
John - SC Support - Posts: 36300
There seems to be some issue with Rithmic today, as we have had several messages about this error with Rithmic. The only thing we can suggest is to try a different server selection, but otherwise you will have to wait for Rithmic to solve the issue.
