Date/Time: Tue, 26 Nov 2024 17:22:22 +0000
scale In issue
View Count: 337
[2023-11-02 15:16:56]
User185210 - Posts: 64
Hello SC,
It seems that there is an issue with the scale in function.
When Long qty 2x and 2 stops, if I add 1x with one stop scale In parameter as "Furthest Orders", it works fine
meaning for example: 2x long ES average price 4300, 1x stop@4290 and 1x stop@4280, when scale in 1x qty, total qty becomes 3, and stops : 1x stop@ 4290 and 2x stop@4280 (furthest order).
It does not behave the same when short position open:
For example:
qty 2x, average price ES 4300 with 1x stop@4310 and 1x stop@4320, when scale In , total qty3, and stops: 2x stop@4310 and 1x stop@4320.
I expect it to be 1x stop@4310 and 2x stop@4320 (this is the furthest order!).
Am I understanding that function correctly?
Thank you for your help.
[2023-11-03 14:54:04]
Sierra_Chart Engineering - Posts: 17182
We will check on this.
[2023-11-03 16:46:48]
There currently is no support for Scale In using stop orders only. Scale In functionality relies on Target orders only.
[2023-11-03 17:41:42]
Hope to have this working soon for stop orders as well!
Thank you
[2023-11-03 17:46:54]
We will implement support for this in the next release.
[2023-11-03 17:52:49]
It is part of a strategy and will be very usefull!
Thank you
