Date/Time: Tue, 26 Nov 2024 17:31:09 +0000
Data/Trade Service Settings configuration question
View Count: 314
[2023-11-02 13:21:43]
User472193 - Posts: 3
Hi SC Support,
Under, "Data/Trade Service Settings" > "Main Settings" > "Service Settings" I have selected my Clearing Firm to be "AMP".
The interface then shows a setting called, "use backup connectivity as primary", with either "yes" or "no" as the options.
Can you explain what this setting is for?
[2023-11-02 14:24:55]
Sierra_Chart Engineering - Posts: 17182
That definitely should be set to No.
The backup connection has higher latency and you do not want to use that as the primary connection.
