Date/Time: Tue, 26 Nov 2024 17:34:53 +0000
My Dom shows Delayed
View Count: 264
[2023-11-02 12:42:42] |
User761234 - Posts: 21 |
Hello guys, I was using the DOM on the chart for now but I'm looking into changing my habits to a separated DOM. I trade M6E futures, and when I opened the separated DOM shows "Delayed" on the Title. How can I fix this? Thank you
[2023-11-02 14:29:48] |
Sierra_Chart Engineering - Posts: 17182 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
