Date/Time: Tue, 26 Nov 2024 16:39:31 +0000
False Values in intraday chart in Bovespa ( IND code BMF exchange )
View Count: 399
[2023-11-02 12:18:53] |
User368741 - Posts: 17 |
The values for intraday chart appears to be wrong as the value at the same time in historical daily chart are very different even though the roll setting for both of the chartbooks are same what might be the reason for this and solution also
[2023-11-02 14:25:36] |
Sierra_Chart Engineering - Posts: 17182 |
Tell us the exact symbol you are referring to but we do not have control over this data.
[2023-11-03 10:09:50] |
INDZ23-BMF
[2023-11-03 10:10:19] |
So the data can be false and nothing can be done ?
[2023-11-06 15:19:25] |
We need to tell our data provider about this.
[2023-11-06 21:43:11] |
This is what our data provider said: I spot checked Friday and it looks good to me, also matches what B3 published.
https://www.barchart.com/futures/quotes/XIZ23/interactive-chart https://www2.bmf.com.br/pages/portal/bmfbovespa/boletim2/SistemaPregao2.asp?pagetype=pop&caminho=Floor%20and%20Electronic%20Trading&Data=11/03/2023&Mercadoria=IND If you have more information, I can review. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
