Date/Time: Tue, 26 Nov 2024 17:36:51 +0000
VbP Visible
View Count: 290
[2023-11-01 18:50:48]
User651547 - Posts: 59
Hi. i use VbP Visible studie. see attached. i have 3 lines on the chart VAH , VAL , PoC. why when i move the time line the value ( price ) of this lines is changed ? i mus be independed for the time line , see the picture for reference .
imagevbp-1.png / V - Attached On 2023-11-01 18:47:42 UTC - Size: 94.85 KB - 74 views
attachmentvbp-2.bmp - Attached On 2023-11-01 18:49:35 UTC - Size: 5.76 MB - 199 views
attachmentvbp-3.bmp - Attached On 2023-11-01 18:50:33 UTC - Size: 5.76 MB - 221 views
[2023-11-01 19:41:44]
John - SC Support - Posts: 36300
The reason for this is because you have your "Volume by Price" study set to display based on the "Visible Bars". Therefore, as you change the timeline, the bars that are visible are changing, and therefore the POC, VAH, and VAL are changing. Refer to the following:
Volume By Price Study: Visible Bars
[2023-11-01 20:09:49]
Can I solve it ?
[2023-11-01 20:26:47]
Do not use the option of "Visible Bars". If you want a specific timeframe then use one of the "Volume Graph Draw Types" that meets your needs. Refer to the following:
Volume By Price Study: Volume Graph Period Type
