Date/Time: Tue, 26 Nov 2024 17:38:28 +0000
Performance-Emergency-Case.: After having used the Replay-function, SC stays slow, even af
View Count: 296
[2023-11-01 15:18:44]
User408639 - Posts: 69
Moin Moin.
This is a bit of a Performance-Emergency-Case.:
Using the Replay-function can make SC slow (, which is fine, as there is a lot to do).
But, SC stays slow, even after.:
1. having stopped the Replay,
2. restarted SC,
3. used "Reload and Recalculate".
Yesterday, I could be editing my TPOs just fine.
Today, after the Replay-adventure, every single click takes about a second to react.
I did already ask.:
1. G7fx's discord-support,
2. google,
3. ChatGPT (albeit with some garbled hints on, where to find the commands).
Do You have any hints.:
You are my last hope, Obi-Wan.
_Tschüß,
__Michael.
P.S.: Just in case, that You need it. I did attach the Chartbook.
By the way.: reducing the number of charts to 1 by duplicating it into a new book, did not solve the problem.
attachmentm6e1!.Schulung mit Hypothese.Cht - Attached On 2023-11-01 15:17:33 UTC - Size: 83.71 KB - 415 views
[2023-11-01 17:28:35]
John - SC Support - Posts: 36300
Since you reference a TPO chart specifically, you may need to increase the "Letter/Block Price Increment in Ticks". Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks
Also refer to the following regarding the above:
Time Price Opportunity (TPO) Profile Charts: The Effect of Letter/Block Price Increment Setting
And then refer to the following for more general things you can look into to increase performance:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart
